  • Lukittu aihe
Aihe OO 5 MILJADIA/ vuodessa  (Luettu 41426 kertaa)
arvosupi
Vs: OO 5 MILJADIA/ vuodessa
Eiköhän selkeä vastis ole. .. ....
CIA/ SUPO sekoiluterrorista huolimatta kohteita on r i i t t ä v ä s t i !
Erityisen hienoa, että myös kansainvälisiä foorumeita. joihin onneksemme SUPO-elukoillakaan EI ole valtaa!. .. ... 8) 8) 8)
arvosupi
_________________________________
Arto Lauri 110. The Photon
https://www.youtube.com/watch?v=Nwj4dni_hic
Henri Lentonen/ Tomi Tee Tuomala haastattelu
https://soundcloud.com/tomi-tee-1/asiantuntija-haastattelu
Arto Lauri 109. Wor War III
https://www.youtube.com/watch?v=RIn4urM9WHo
Electron Volt = temperature in Kelvin
wow wow wow wow wow wow
The electron volt, and text temperature Wiki.
A certain areas of physics, such as plasma physics, it is practical to use mass to a temperature in electron volts
determined using Bolzmann constant kB:
1eV        1,60217653(14) X 10^-19J
_____= _________________________ = 11 604,505(20) K
 kB        1,3806505(24) X 10^-23J/K
For example, a typical magnetic fusion plasma is limited 15kV or 175 million degrees Kelvin.
The numbers in parentheses are the measured value of the last two digits the standard deviation.
Ekvipartitio theorem of classical thermal equilibrium thermodynamic system the average energy per degree of freedom is ½kT, where T is the temperature. The ideal gas particles have three degrees of freedom, so the ideal gas energy per particle an average of 3 / 2kT.
That's Mark's last formula is a professional expert quite TOP! According to that should now be able to directly determine the 200MeV explosive single uranium atom temperature in the reactor directly. The nuclear bomb is defined directly in the millions of degrees! There is thus a nuclear reactor STUK lies + 300C at all!
This is ever so important piece of information Marco. As evidence directly previous argument that a nuclear reactor uranium fuel is always based on the fumed pressurized air directly PLASMA GAS IN! Can Marco shows the relevant data more formula? Russian data on the other hand says uranium pellet temperature is always more than the uranium boiling + 4131C. The class + 5000C. So the fork temperatures IS. But ALWAYS uranium occurs CHANNEL RADIUS gas!
* Self calculator uranium pellets in the internal temperature of the power; / cm3 according to. Metal halide lamp 4 200K with the formation of 100W / cm 3 according to.
And when the uranium in the capsule while it is 148W / cm 3. Produce the temperature here
148W / cm 3 / 100W / cm3 4200K = X + 6 216k uranium pellets rattling temperature. That is more than six 000C
Marco
"If the capsule is formed around the uranium Tsherenkov general type of plasma, is a capsule where the water collects in vacuo, and the gases ..."
* Yes, there is, so that when the plasma radiation, the pressure is formed, so that the gas pressure due around there is so little air molecules / cm 3. That technically it is a vacuum! Well noticed brings ..
Elektronivoltti= lämpötila kelvineinä
woW Wow Wow woW Wow woW
Elektronivoltti ja lämpötila Wikitekstistä
Tietyllä fysiikan alueilla, esimerkiksi plasmafysiikassa on käytännöllistä käyttää elektronivolttia massan lämpötilaan
määritellään  käyttäen BOLZMANNIN vakiota kB:
Esimerkiksi tyypillinen magneettisesti rajoitetun fuusion plasma on 15kV tai 175 miljoonaa kelviniä.
Suluissa olevat numerot ovat mitatun arvon kahden viimeisen numeron keskihajonta.
Klassisen ekvipartitio teoreeman mukaan termisessä tasapainossa olevan termodynaamisen järjestelmän keskimääräinen energia vapausastetta kohti on ½kT, missä T on lämpötila. Ideaalikaasun hiukkasilla on kolme vapausastetta, joten ideaalikaasun keskimääräinen energia hiukkasta kohti on 3/2kT.
Tuo Marcon viimeinenkin kaava on ammattiosaajan ihan HUIPPUA! Tuon mukaan pitäisi nyt kyetä suoraan määrittelemään 200MeV räjähtävän yksittäisen uraaniatomin LÄMPÖTILAT reaktorissa suoraan. Ydinpommissa se määritellään suoraan olevan MILJOONISSA ASTEISSA! Ei siis ydinreaktorin STUK- valheiden +300C alkuunkaan!
Tämä on HURJAN tärkeä tieto Marcolta. Koska todistaa SUORAAN aiemman väitteen, että ydinreaktorissa uraanin poltto perustuu AINA ilmaan suoraan höyrystetyissä paineistetuissa PLASMAKAASUISSA! Osaako Marco esittää asiaan lisää kaavadataa? Venäläinen data toisaalta sanoo uraanipelletin lämpötilan olevan aina yli uraanin kiehumisen +4131C. Luokkaa + 5000C. Joten haarukkaa lämpötiloissa ON. Mutta AINA uraani esiintyy KANAVASÄDE KAASUNA!
* Itse laskin uraanipelletin sisäisen lämpötilan tehona/cm3 mukaan.
Metallihalidi lampun +4 200K  kun muodostuu 100W/cm3 mukaan.
Ja kun uraani kapselissa se taas on 148W/cm3. Saadaan lämpötila tästä:
148W/cm3/ 100W/ cm3 X 4200K=  + 6 216K  on uraanipelletin hurja lämpötila. Eli yli +6 000C
Marco
"Jos uraanin kapselin ympärille muodostuu ylipäätään Tsherenkov tyyppistä plasma, on kapseli silloin tyhjiössä ja vesi kerää kaasut..."
* On kyllä niin, että KUN plasmaa säteilyn vastapaineesta muodostuu, niin tämän kaasun paineen takia ympärillä ON niin vähän ilmamolekyylejä/ cm3. Että teknisesti kyse ON tyhjiöstä! Hyvin huomattu tuokin..
Salaliittoteoria on ihmisen keksimä salainen liittoutuma, jonka tavoitteena on tehdä jotain, josta sinä et pidä. Yleensä salaliittoa ei ole olemassa, kunnes joku ulkopuolinen ihminen keksii sen.
 Yleensä salaliitto muuttuu uskottavaksi vasta kun salaliiton jäsenet kovaäänisesti kiistävät salaliiton olemassaolon.
Tyypillinen salaliitto on siis aivan samanlaista kuin suklaakakun leipominen ilman suklaata; sen pitäisi olla siellä, mutta ei ole - ja kaikki tietävät sen. Ja suklaakakku on juuri se, mitä sinä ja ystäväsi haluavat. Mutta täällä ei ole jauhoja, eikä suklaata. Ei edes kookospähkinöitä tai CIA:ta siivoamassa leipomisen jälkiä.
Mutta älä katso taaksesi, koska he saattavat huomata, että tiedät niistä. On parasta, että pidät ne tietämättöminä siitä että tiedät, ja jokainen salaliiton peittelyn kohteeksi joutunut tietää tämän.
Siksi jokainen salaliittoteoria, jonka kohtaat on siksi ainoastaan harhainen luulo, joilla peitetään oikeaa totuutta.
The Truth is Out There
arvosupi
TVO MOX polttoon
mox mox mox mox
Kuvaavaa on, että TVO:lla on töissä luokkaa 800 ydinorjaa. Ollut töissä yli 40 vuotta. Nykyään ydinalan kannattavuuden rippeetkin on romuttuneen. Siksi TVO irtisanoi SADOISSA 2015 alusta. Kuten yhtiö ilmoitti:
" Jatkuvasti kasvavien nimenomaan ydinenergian tuotannon kannattamattomuuksien räjähdysmäisten kasvamisten takia!" Viikolla 17 myös Nordea kommentoi asiaa:" Energia-alaan ennakoidaan suunnatonta - 9,6% laskua myös vuoteen 2015. Ydinhankkeitten oletetun +5%/y sijaan! Joka laskuna kohdistuu erityisen pahastu ydinyhtiöihin Fortumiin, TVO, Fennovoiman suurhankkeisiin!"
Mutta kun TVO aloitti USA ydinasetehtailijoittensa kanssa tuomaan laitonta Fukushimassa myös fissioiden kaasuiksi räjähtänyttä 100% YDINASE MOX- polttoaineen tuotantoa. Joka on 2,5 kertaa kalliimpaa aiempaan uraanipolttoaineen sähkön hintaan, että myös kertaluokkia ENERGIANEGATIIVISTA. Rahaa TVO/ Posiva aikovat saada sähkön sijasta myymällä laitonta Pu-239 tuotantoaan entistä räikeämmin aseiksi maksukykyisille Maailmaan!
Niin firma käynnisti 2015 alusta LAITTOMASTI mm. koko voimalaa kiertäneet 10 000V TAPPAVAT sähköaidat.! Kansainvälisen YDINASEMATERIAALIEN säilytys ydinvoimala- alueilla. Antoi alueen 120 varioinnista vastaaville epäpäteville vain parin viikon pikakurssitetuille sotilaspoliiseille mm. singot ja konetuliaseet kaikille! IAEA tilanteesta vastaaviin uusittuihin USA ydinlisenssin haltian määräyksiin kuuluu seuraavia.
Ettei vartijoiden kovat piipussa olevat konetuliaseet SAA näkyä virka- aikoina. Vain kello 16:00- 6:00 välisinä aikoina konetuliaseet on näkyvillä, mutta aina mukana. Ydinyhtiö on hankkinut lisäksi mm. Suomen kalleimmat tutkasysteemit länsirannan säämastonsa puoliväliin. Meri- maa-ilmatutkakseen. Alistettuna vielä SUORAAN Tampereen sotalennostolle, lentokoneitten ohjuksien hallintaan sekin. Lisäksi TVO on hommannut länsirannalleen kuuntelulaitteita ja ties montako muuta ohjussysteemiä ja miinoituslaitteitaan pitkin rannikkoa. Metallisia piilotettuja erinäisten "laitteitten" ainoat kuvat löytyvät Arto Lauri Yotube video:
https://www.youtube.com/watch?v=K5wbG8e456E
Tutusti äärimmäisen rohkeasti, Olkiluoto alueen sotapoliisien pyssynpiippujen osittamisen hengenvaarallisissa olosuhteissa otetuissa otoksissaan.
arvosupi
Kaikkia varmaan kiinnostaa tietää, että TVO:lla toimii KA4 niminen ydinalan nettisotilas yksikkö. Viimeisimmän tiedon mukaan 2015 alussa sinne TVO palkkasi entisten insinöörimassojensa lisäksi 30 CIA/Army agenttia. No samalla Poriin palkkasivat Anne Holmlundin tahdosta 17 ydinalan kybersotilasta. Pelkästään Vuojoella 15km  TVO:lta toimii vielä 12kpl kybersotayksikköä.
Arton videoista hahmottuu kartanon alaosaan rakennettu 400kW valvontatietokonearmeijat ja linkkimastot jodifiltteriputken viereltä.  Edes paikallisen Eurajoen teleosuuskunnan johtajaa bunkkeriin EI päästetä.! Toisaalta Arto on kyllä tiloissa käynyt. Ja tietää siksi tarkoin tämänkin SUPO systeemin salaisuudet! Ja sekös SUPO POLIISEJA harmittaa.)
Kuvitelkaa, että kaikki tällainen on lisätty ja tehty kun SUPO huomasi ydinasetehtaittensa tietojen alkavan huolestuttavasti vuotaa Arto:n videoimana julkisuuteen. TVO:n johtaja kertoikin suoraan, että TVO on menettänyt Arton paljastuksissa MILJARDIEN BISNESMAHDOLLISUUDET laittomissa ydinmateriaalien hankkeissa! Siksi TVO/Posiva ovat niin suunnattoman katkeria. Koska sitä ennen jopa 40v ongelmitta kestäneet ydinalan salaisuudet paljastuivat.
Koetin uutista etsiä saman tien myös TV-teksti TV puolelta. Mutta eivät olleet päästäneet edes sinne. Fortumille tieto -9,6% energiakysynnän laskusta on siis DE FACTO! Todettu niin vaaralliseksi, että SUPO sensuroi sitä aggressiivisesti saman tien.
Luomujussi
  • Expertus dico....
Onx meillä ydinasetehtaita.....kumpa oliskin ja mitä tarkoitat laittomilla ydinmateriiaalilla....
arvosupi
JOKAINEN reaktori lakkasi olemasta energian tuottaja 2008<.
Mutta ydinasetehtaiksi ne on alkujaankin tehty.
Laitonta ydinasemateriaalin myynti Suomen lakien mukaan toki ON.
Mutta yksikään maamme ydinyhtiö ei ole tätä lakia koskaan kuunnelleet.
Vaan Suomi aloitti ydinasemateriaaliensa junalla tehdyt myynnit Loviisasta ja myöhemmin Olkiluodosta alusta asti 1975<.
Vaikka myynti on 100% rikollista. Yksikään maamme läpeensä korruptoitu viranomaistaho eivät korruptoituina ole asiaan ikinä puuttuneet.
arvosupi
- Kuten JOKAINEN voi huomata. Näissä keskusteluissa on nähdysti mukana PELKÄSTÄÄN armeijan kouluttamana,  palkkaamina KYBERSOTAYKSIKKÖJEN pellet![ (Juuri kuten HALUSINKIN osittaa! Kuten lentotutkatiedottamiset osittaa nähdysti Tampereen LENTOSOTAYKSIKÖISTÄ!)/U]
- Siinä meni lopullisesti tunnustuksinaan viemäriin heidän  aiemmat inttämät siitä, että ovat "olevinaan siviilejä" tai ties mitä "yksityisyrittäjiä".!
- Samalla paljastivat 100% kiistatta, että ovat Tampereen lennoston kybersotapoliiseja!!MOT
Tietysti voimme huomata myös sen, että 1950- luvun tutkarohjot ovat nykyisemmin pieniä, näppäriä ja ONGELMITTA TVO:n säämastoonkin sopivia sotilaallisia lentokoneisiin suunniteltuja kevyitä mötiköitä.
Itse tunnen ehkä parhaiten tuollaiset veneisiin laitetut hyvin toimivat minitutkat. Sellaisia pallogrillin näköisiä höyhenen kevyitä koneita. Tässä ihan malliksi alle 50cm kokoinen variaatio:
"GMR 18 HD on tehokas tutka-antenni pienessä koossa. 18 tuumaisena ja 4 kW lähetysteholla se on kaksikertaa tehokkaampi kuin kilpailijoiden saman koko tai hintaluokan tutka-antennit. 5.2° vaakakeilan leveys mahdollistaa veneen tarkan kohdentamisen ja suuntaamisen sateessa sekä sumussa. "
arvosupi
Arto Laur 111. Bolzmann constant
https://www.youtube.com/watch?v=uJwiXRIkImA
Plasma VACUUM
what what what
> <Marco
> "If the uranium is formed around the capsule type plasma Tsherenkov in general, is a capsule where the water collects in vacuo, and the gases ...">
> * It is indeed so that when the plasma radiation, the pressure is formed, so that the gas pressure because there are so few around (EE Lähteenkorva specified by the vital intermediary electron-containing air molecules / cm 3.) So technically it is a vacuum! Well noticed brings ..
> This is what interests me, therefore, that the plasma has the vacuum features!
> Terv: J
* Had the CIA / SUPO teeth and illegally made redundant within 2h. Because his works dealt with chemitrail projects related to the secret, for example, Vaisala available climate reports. Guy seems to be held secret data, such as the most recent Bolzmann- videostani you notice.
That radiation pressure generated by the vacuum is otherwise LARGE encrypted mystery. I thought myself that the world's hottest point could be found in black hole. When I was looking out the background for my video. But what yet! While opening a vacuum cleaner material at point than which. The black hole's temperature is the most complete VACUUM what is known! ..
 Temperature ABSOLUTE VACUUM!
This is only possible when opening flung radiation pressure. Hawk virtual radiation from the drive ALL transmit energy electrons off. This finding is in my view, stunning. You know, I always wondered why the glowing hot uranium capsules under water TVO Rh-eye appears to be in the hall. Not supposed white-hot, but unbelievably super black! The only inside the energy out of feeding the visible phenomenon is TSHERENKOVIN veil flocking to convey the energy of electrons.
http://kuvapilvi.fi/k/yHga.jpg
 ;D ;D
Fuckin great.... ;D
arvosupi
Plasma VACUUM
what what what
> Terv: J
[Img] http://kuvapilvi.fi/k/yHga.jpg [/ img]
Plasman TYHJIÖ
mikä mikä mikä
> > "Jos uraanin kapselin ympärille muodostuu ylipäätään Tsherenkov tyyppistä plasma, on kapseli silloin tyhjiössä ja vesi kerää kaasut...">
> * On kyllä niin, että KUN plasmaa säteilyn vastapaineesta muodostuu, niin tämän kaasun paineen takia ympärillä ON niin vähän (E.E. Lähteenkorvan mainitsemia elintärkeitä, välittäjä elektroneja sisältäviä ilmamolekyylejä/ cm3.) Että teknisesti kyse ON tyhjiöstä! Hyvin huomattu tuokin..
> Tämä minua kiinnostaisi siis että Plasmalla on Tyhjiön ominaisuudet!
> terv: J
* Joutui CIA/ SUPO hampaisiin ja laittomasti irtisanotuksi 2h sisällä. Koska töissään käsitteli chemitrail hankkeisiin liittyviä salaisia esimerkiksi Vaisalassa saatavia ilmaston raportteja. Kaverilla näyttää olevan hallussa salaista dataa, kuten uusimmasta Bolzmann- videostani huomaat.
Tuo säteilypaineen synnyttämä tyhjiö on muuten SUURI salattu mysteeri. Luulin itsekin, että maailman kuumin piste löytyisi Mustasta aukosta. Kun etsin asian taustaa videotani varten. Mutta mitä vielä! Vaikka aukko imuroi ainetta pisteeseensä kuin mikäkin. Mustan aukon lämpötila on täydellisin TYHJIÖ mitä tunnetaan!..
Lämpötila ABSOLUUTTINEN TYHJIÖ!
Tämä on mahdollista VAIN kun aukosta sinkoavat säteilyn paineet. Hawkinin virtuaalisäteilystä lähtien ajaa KAIKKI energiaa välittävät elektronit pois. Havainto on mielestäni mykistävä. Tiedätkö, olen AINA ihmetellyt, miksi hehkuvan kuumat uraani kapselit veden alla TVO Rh-hallissa silmiin näyttäytyy. Ei oletetun valkohehkuisina, vaan käsittämättömän super mustina! Ainoa sisältä energiaa ulos syöttävä näkyvä ilmiö on TSHERENKOVIN hunnun parveilevat energiaa välittävät elektronit.
Pilvee pilvee, tyhjiöpää. ;D
http://www.masinistit.com/viewtopic.php?t=35559&postdays=0&postorder=asc&start=20&sid=36598136e60c49a4f5ee788ac496027d
Anssi
Site Admin
uu, annanpa minäkin tämän viikonlopun aikaa Leyland 262 miehelle saada Raija keskustelemaan asiallisesti masinistiasioista.
Maanantaina tulee sitten kenkää tällekin inkarnaatiolle jälleen mikäli ei jostakin syystä onnistu.
Leyland 262 mies
Ensinnäkin minä luulin että Anssi ei peritä tuumaakaan . Toiseksi minulla ihan oikeasti ei ole ammattitaitoa näissä mielenterveys asioissa.
Piti soittaa eräälle tutulle, mutta olikin näemmä muuttanut sellaiseen paikkaan missä ei ole kännyköitä. Asiantuntija on poissa, pitää selvitä nyt omillaan.
Johan oli muuten myös sähköinsinööri ja luki itsensä psykologia professoriksi.
http://www.uta.fi/laitokset/psyk/hlokunta/inmemoriam/Johan_Weckroth.htm
Tämä sama kirjoitus löytyy monesta paikasta:
http://www.google.fi/search?client=firefox-a&rls=org.mozilla%3Aen-US%3Aofficial&channel=s&hl=fi&source=hp&q=Tarkoitat+n%C3%A4it%C3%A4+muoveja%2C+jotka+tosiaan+oltuaan+hetken+aikaa+valossa+kuten+kerroit+ihan+LIVE%3An%C3%A4+demoten+vastoin+STUK+valheita+ongelmitta+varastoi+valofotoneja.+T%C3%A4llaista+jopa+maalipintaa+leviteltiin+TVO%3Alla+seiniin+satoja+litroja.+Niiden+tarkoitus+on+varast&meta=&btnG=Google-haku
Kyseessä on oikealta nimeltään Arto Lauri, joka sai skitsofreniansa takia potkut ydinvoimalan sähköasentajan hommistaan. Sairauden oireina ilmenee kaikkien epäedullisten tapahtumien yhdistäminen ydinvoimaan (metsätuhot, mehiläiskadot, kalatuhot, kampamaneetit, jalkasilsa ym.) sekä megalomania joka ilmenee siinä että hän on ainoa ihminen maailmassa joka ymmärtää "ydinsalatieteitä" ja jota arvon viranomaistaho sen takia vainoaa. Sen jälkeen hän on saanut varomattomista medioista toistuvasti palstatilaa käsitystensä esittelemiseen sekä pommittanut salanimillä kaikkia mahdollisia nettifoorumeita.
Skitsofreniaa sairastaa noin yksi prosentti ihmisistä. Skitsofreniaan sairastuminen tarkoittaa vaikeata persoonallisuuden koossapitävien voimien vähenemistä, siten että todellisuudentaju ja toimintakyky heikkenevät. Tähän liittyy usein sosiaalisista kontakteista vetäytymistä. Skitsofreniaa sairastava ei erota mielikuvitusta todellisuudesta, ja hänen on hyvin vaikea ajatella luovasti sekä ilmaista erilaisia tunteita, kuten pelkoa tai rakkautta. Sairauteen liittyy myös vaikeuksia muistitoiminnoissa ja tarkkaavaisuudessa. Yksi tärkeimmästä skitsofrenian ennusteeseen vaikuttavista tekijöistä on varhainen hoitoon hakeutuminen.
Lukekaa ja etsikää haulla itse lisää tietoa skitsofreniasta. …
Anssi
Site Admin
Leyland 262 mies
Onko tuo sama asia näittenkin kohdalla, jotka kirjoittavat tännekkin saitille joka päivä. "kepu pettää aina, jne..."?
